I wrote something about using greek and cyrillic fonts in one line in this forum - it is possible but I have to search for it as it is about two or three years ago. Look for the word "greek" if you want to search as well
Hannes
19 years 2 months
Member for19 years2 months
Submitted by Wladyslaw Woloszyn on Thu, 2009-09-24 10:32
The reason to use the two fields is because you are very limited in the number of characters available in Activity description (48). If your act. descriptions are short then you can write boths languages in that field.
JMFrade
19 years 2 months
Submitted by Wladyslaw Woloszyn on Thu, 2009-09-24 05:31
The only thing you need to be aware is that the language you use in a Log field cannot be displayed in columns. It will appear in the gant chart (for instance) next to the activity bar but not as a column like you normaly have for the Activity description.
20 years 3 monthsRE: Using two languages in p3
Hi Wladyslaw
Hannes
19 years 2 monthsRE: Using two languages in p3
Hello Jose,
Thans for advance. The problem is also with specific russion (cyrillic) fonts.
W.Woloszyn
20 years 5 monthsRE: Using two languages in p3
Good morning,
JMFrade
Does it means is not possible to have 2 languages description in one line e.g. Activity description:
Purchase Order / заказ на покупку.
Or phase description: Engineering / базовое проектирование.
Only possibility is to haveactivity description in english and log in russian?
Hi Woloszyn.
That, is a possbible solution.
I hope it helped some how...
BR
JMFrade
