P3/P6 Global Variable
16 years 11 months
There are few functions in global change option that would help you to modify the existing activity IDs as i posted in last message
18 years 11 months
Hi Dinesh,
P3/P6 dont have the facilities using global change to auto increment Activity ID. The easiest way is to export it to other software like excel then import back again. Excel has robust facilities in changing text and integers including automatic renumberingincluding the formula like concactenate .
Hope this this provide solution.
Ronald
16 years 11 months
Any clarificaiton of global change functions you could post on this thread so that seniors out here will get you better solution
19 years 5 months
Thanks Shahul let me check
16 years 11 months
Hi dinesh you could modify your activity ID in P3 using global change ,check out in help {P3} and search for global change you might come across list of functions like RIGHT,LEFT and so on which would help you to modify your activity ID in easy way out
16 years 11 months
Yes there is a way out in global change .I will get back soon
19 years 5 months
In fact, When I was done with my schedule, Client came up with an activity ID coding system. So now I’m forced to change all the activity IDs (about 1000 of them in number) to suit. Is there a way out for this with a Global change?
16 years 11 months
Dinesh ,you need to increment a activity through global change option?
