wondering at your question, do you want to edit the page footer note? if yes, you could replace this with any logo in your case your companies name easily. if it is created as a default layout by your administrator, you need to have the correct privilages to do the change by yourself or ask your administrator to change it for you.
hope this helps or else get back to us for further info
16 years 11 monthsRE: change primavera trademark lower left print
Hi friends
I faced the same problem i am unable to set image of my organisation logo in footer
I am waiting for the response from seniors of Planning planet.
16 years 5 monthsRE: change primavera trademark lower left print
I got the same question:
Independent from what you define to print in the lower-left corner of the footer, theres always a trademark that reads:
(c) Primavera Systems, Inc.
Is there a way to remove this trademark? It is not defined in the footer window, but it prints in the footer.
20 years 11 monthsRE: change primavera trademark lower left print
Gun,
cheers
Wazsab
