ODBC Driver for P3.1
18 years
guys, is there any ODBC drivers for P3.1 if my system is vista?
21 years 8 months
I will move to your thread on P3 won’t run, your issue/(our as I had the same problems) on P3 WON’T WORK is RELEVANT TO ANY IN NEED TO INSTALL OBDC DRIVERS, they should be aware of the possible traps.
18 years 5 months
Yes, u r absolutely right.
Also Rafael, those drivers are for Windows NT / 2000 only and not for Xp or for Vista.
If u install them on higher version, then it creates problem to your database.
Please check the version of the pervasive ODBC drivers before installation.
Plz advise.
21 years 8 months
Before installing new software always remember to backup your Data and System Files and/or a Full Backup. At minimum a registry backup.
Database setup is very tricky, avoid messing with them unless you backup and know what the software is doing to your system. This is the main reason I am against P6 as a solution for those not in need of entreprise Stuff.
16 years 4 months
Thank you very much! I have uploaded the files.
Ernani
16 years 11 months
Please tell what exactly to download because I have visited the website and get lost. I do not know where to go to download the driver. Thanks!
