I dont have access to P3 any longer, but from what I recall you need to enable Compressed Backup which creates the single .PRX file.
The normal save will update the 23 files that were created when the project was created and you cant get away from this. The backup is used for backing up (!) the project and to facilitate easy emailing.
If you have the manual, look up PRX in the index, as well as Backup.
22 years 10 monthsRE: Saving to 1 file - P3.ini Options
Here is what I have in my P3.INI file and I get .PRX compressed files,
[BackupRestoreOptions]
UseOldCompression=0
Specifications=1
SubProjectRelations=1
MergeSubDictionaries=0
RemoveAccessList=1
Compressed=1
BackupExternalActs=0
I believe that you also need at least Version 2.0b of P3 to make this work. Good luck!
21 years 5 monthsRE: Saving to 1 file - P3.ini Options
Trent
Hope this helps.
John
17 years 11 monthsRE: Saving to 1 file - P3.ini Options
Save to one file? Did you mean prx file? Have you tried this way before?
Tom
