I doubt if that problem cant be work-out. I suggest for you to switch on the automatic leveling and scheduling when you are making the changes in the program so wont repeatedly be going through the commands.
Dont stop. Keep on developing the program until you succefully meet your objective.
Good luck.
17 years
Member for17 years
Submitted by harzelli bouasria on Thu, 2008-11-13 04:27
Furthermore, try to check as well your activities relationship. You might find some of it that may require enhancement. You may also you use "LAG" for a more realistic approach in the different interfaces of your program.
Ferdinand
17 years 3 months
Member for17 years3 months
Submitted by Ferdinand Finc… on Thu, 2008-11-13 01:14
You need to make a keen reviewing of your activities duration and figure out its possibilities of shortening durations. Just a suggestion, in the process of your duration evaluation, try to make it from the backend of the program since the end activities are somehow uncertain to be thoroughly figured out of its timely implementation. Besides, backend activities are often subject to changes and variation as the project progresses, and further, everything therein is the product of the front-end activities. Front-end activities then are the more realistic in your time scheduling as you see it upfront in your current program development.
Another thing that I guess you need to check is the leveling priority of your tasks. Try to experiment with the different criterias in leveling your program until you find the more suitable and realistic result in your requirement.
17 years 3 monthsRE: operations after leveling ressources
Good luck.
17 yearsRE: operations after leveling ressources
hi ferdinand
I tried all these solution before, but it has not set the problem
thanks
Harzelli,
Ferdinand
Hello Harzelli,
Simply sharing.
Ferdinand
