In addition to what Jackie said, one may really need not delete programmed activities especially in a Master Program since it somehow implies to work variations and changes. Record of which can actually be utilized in future program (delay) analysis and presentations. I actually have done it that way in my recently completed project with enormous additional works and variations.
Simply sharing.
Ferdinand
20 years 7 months
Member for20 years7 months
Submitted by Jackie Gilliland on Tue, 2008-11-04 07:53
You could possibly leave the activities in your schedule and code them as deleted activities. This would allow you to filter them in or out as you wish.
Just ensure you fix them in position and remove logic from them so as to not allow them to impact your schedule.
Also ensure you set it up as to not have cost or resource data corrupting your reports.
This is not ideal but could work for your situation
22 years 11 months
Member for23 years
Submitted by Steven Oliver on Tue, 2008-11-04 06:37
I think , even if my boss has asked for something which is not possible in P3. But i agree that what he has asked is quite logical from execution and record point of view. We all do face sometime or other the situation , where we have to start redoing activites again due to some reasons in my case , it is change of location.So engg. activites related to that location has now become redundant.
Does any one know , of any other software where this type of facility is available or let me know , what do you do when faced with such type of situation.
Ok, you will see more bars from your baseline/target compared to your current schedule, but it doest represent anything. You are right, baseline for nothing, but it will serve as a reminder that originally, your plan has that certain activity or activities.
cheers!
17 years 3 months
Member for17 years3 months
Submitted by Ferdinand Finc… on Sun, 2008-11-02 07:41
I know what you mean. This line of Vinods questioning is what is bothering me, "..to see in ongoing program , baseline bars for activites that were deleted...". It is then the question of presentation on how to show such baseline bar of an activity that has been deleted or no longer existent in that particular ongoing program. Is that still possible?
Please read post no. 1, it was mentioned that the baseline was saved. Assuming that the changes (deleted activities) were done only on the Current/Working schedule, it doesnt affect the saved Baseline/Target. Vinod can still show all the bars of the Target even if not consistent with the current/working schedule anymore. Thru it, you will see the difference between your Current against your Baseline/Target (in terms of number of activities or in any way). Oh by the way, you also can have two targets/baselines at the same time.
hope its clear.
18 years 9 months
Member for18 years9 months
Submitted by Dieter Wambach on Sun, 2008-11-02 04:57
Baseline is referenced by activity id. In your main project youll have to create activities with the same id as those in the baseline. then those activities will be displayed again.
17 years 3 months
Submitted by Ferdinand Finc… on Sun, 2008-11-02 02:35
Are you sure that you had saved your baseline (target)? If you did, then its still intact even if you have deleted all the activities of your Current Schedule. But if you have deleted the baseline/target itself, then its time to prepare a new one.
If you want to see the target bars, you need to select/show it. P3 can show 3 bars in a row.
17 years 3 months
Submitted by Ferdinand Finc… on Sat, 2008-11-01 06:14
It seems that your boss knows a lot about Primavera or he simply is a dumb when it comes to Primavera usage. All I know is that when you delete an activity in the program it is forever gone along with its baseline and other formatting with no trace or shadow in its database.
Hope the experts in here may share some idea on your query and to my above reply as I may have said wrong information to you.
17 years 3 monthsRE: How to show deleted baseline bars , in ongoing program?
Hi to all,
Simply sharing.
Ferdinand
20 years 7 monthsRE: How to show deleted baseline bars , in ongoing program?
22 years 11 monthsRE: How to show deleted baseline bars , in ongoing program?
You could make your current version a baseline to your original target.
19 years 2 monthsRE: How to show deleted baseline bars , in ongoing program?
Hi All ,
Expecting few replies on this.
19 years 1 monthRE: How to show deleted baseline bars , in ongoing program?
Ferdinand,
cheers!
Hi Anoon and all,
Thanks and be patient with me.
Cheers!
Ferdinand,
hope its clear.
18 years 9 monthsRE: How to show deleted baseline bars , in ongoing program?
Vinod
A BASELINE WITH DELETED ACTIVITIES?????
WHATS THE USE?
PLEASE EXPLAIN FURTHER. PLEASE SHARE THAT KNOWLEDGE.
THANKS.
Hi Vinod,
Cheers! Its just a one dirham share from me.
Ferdinand
