Activity Id, % Complete, Actual Start (AS), Actual Finish (AF)
My experience is that; if the first line item for AS or AF in the table is blank, then for some reasons, it changes AS or AF column to text; and if you happen not to check before importing, then youll probably import progress data with no finish dates. To get round it, I sort the data by AF, then by AS.
If you copy and paste onto an existing DBF file, then you will have to delete and re-create the name...
I checked the project there are no corruption. I found the problem. The problem is coming from importing and exporting. When I updated activities by hand there are no problems. I changed the import and export tables. (All folders etc.) Problem solved. I am using .DBF to importing. If anyone has a more technical explanation. (like format of the file or extension of the folder vs.) I will be glad to hear it.
17 years 5 monthsRE: Urgent Scheduling help please
Than you all,
18 years 9 monthsRE: Urgent Scheduling help please
I use DBF to import data into P3.
In my case, progress import DBF file contains;
Thank you for your support,
Safak
Thank you for your interest. I am both using store period performance and I am importing progresses and actual dates.
Waiting for your reply.
Safak
21 yearsRE: Urgent Scheduling help please
Pinan T.
You do not make clear if you are updating the progress by typing it in or updating it from another source. Are you importing progress from excel?
18 years 3 monthsRE: Urgent Scheduling help please
other than it is corrupted, do you use store period performance?
