Primavera 3.0 to pdf format
17 years 3 months
Jun,
Just want add something to other’s reply.
As far as I know, Adobe Acrobat 7.0 Pro has some difficulty in printing P3 outputs specially if you put some logos other than those coming in bundle with P3. What I recommend is Adobe Acrobat 5.0 which comes with 2 printer drivers, a pdf writer and a distiller. I normally use the distiller whenever I have some graphics embedded on the schedule. So far the 2 programs works happily with each other without complications.
The other pdf writer you can use is the freeware CutePdf program. It also prints P3 with no problem at all. That is as far as I know.
Lastly, check your version of P3 if it is already SP3. If not, you can get the patch from Primavera on their Knowledgebase.
Hope this helps,
22 years 9 months
Jun,
it is easier to select the PDF "printer" before you display the Print Preview, because P3 is accustomed to go back to the default printer
Open File, Print setup, then change the printer to Adobe, and close the dialog
Open File, Print ...
Alexandre
17 years 6 months
Mr. Olike, I already did this but it is not working. Anymore suggestion pls.
18 years 9 months
... print preview, select your PDF printer, then print... should work ok..
