Primavera Project Planner - P3 Member for 10 years 1 month Member for 10 years 1 month Submitted by tjnuneza on Wed, 2016-11-02 12:57 Permalink Hello, I have problem in Hello, I have problem in importing xer p6 file. Error occur "CVRCU-1939-9 Default value provided for field ev_compute_type is not valid" Thank you in advance for your input. COCOY Member for 16 years 3 months Member for 16 years 3 months Submitted by Zoltan Palffy on Tue, 2016-10-25 13:56 Permalink make sure that you have the make sure that you have the correct java version that it is working. Member for 9 years Member for 9 years Submitted by wproject.planner on Tue, 2016-10-25 08:06 Permalink I'm having the same problem. I'm having the same problem. The only solution I came up with, is to start a new database with a new connection and then import all projects all over again. Log in or register to post comments
10 years 1 monthHello, I have problem in
Hello,
COCOY
16 years 3 monthsmake sure that you have the
9 yearsI'm having the same problem.
