In an hourly project, I cant see how the display of DATE and TIME would increase the width of your column. P3 default settings will just display the TIME below the DATE. This however will increase the row height.
If however you want a more narrow column, you can change your data font,..say from arial 8 to arial 6, then the column width will automatically adjust, based on the character width of your selected font and size.
To do this, just double click on the column heading and on the pop up menu, select the "DATA FONT", then click the arrow above and select a smaller font size. You can also customize the title, alignment and width of your column on this menu.
I have already tried these areas of formating the layout but I have found in some of the old layouts in my system the columns are best fit like the option you have in Excel.
Any other ideas?
18 years 9 months
Member for18 years9 months
Submitted by Pranab Kumar Deb on Fri, 2008-04-11 09:29
Press F11 and change the column width to the reqd figure.
Else go to the column Total area and take your mouse pointer to the line inbetween any two column , when the pointer changes to a "H", remove the column divider to any location that you feel is required.
HTH
deb
18 years 2 months
Member for18 years2 months
Submitted by James Barnes on Fri, 2008-04-11 08:54
welcome to the wonderful world of formatting P3 views!
I have found the same problem and have not found a full solution. What does help (a little) is to change the dates format to make the text narrower yet still readable, thus allowing you to narrow the column (a bit).
17 years 7 monthsRE: Column width - how to edit
Hi Steve,
Hope this helps..
Gerry
17 years 9 monthsRE: Column width - how to edit
Thanks guys
Any other ideas?
18 years 9 monthsRE: Column width - how to edit
Hello Steve,
HTH
deb
18 years 2 monthsRE: Column width - how to edit
Steve
Thats as far as I ever go though...
