Import user Define Column from MSP to P v5.0
18 years 9 months
Hi Arun
As P5 is a release status of P3e, you’ll better put posts related to P5 into that category.
For the user defined fields (=UDF): First define them in P5. Then, when you’ll start the import, in the 4th(?) window "Template" you can add a new template or you can just modify an existing one. Walk through the detail tabs. The right one is for the UDF. There you can select source and target field.
As for the codes I sorry, I don’t know.
Good luck!
