if the temp file directory is located on server, please allow every user have his own temp file directory. Some the temp file may be in same name, if one user already "point" to that file, others may have trouble.
18 years 6 months
Member for18 years7 months
Submitted by Mangesh Khuspe on Tue, 2007-10-16 08:02
Do you have appropriate access rights under Window? Temporary files will be written into a certain directoy - in general under P3WIN. Youll need the appropriate rights for this directory.
18 years 6 monthsRE: error message: Unable to create Temporary file
Hi there,
Please check that your project is being saved in sub sub sub directory.
Primevera has a limit for this make a new directory in root and try to save it there.
Ashraf
23 years 8 monthsRE: error message: Unable to create Temporary file
dieter well i do not have proper access rights under windows but these files are not located on c drive, they are located on main server.
but if i guess that the temporary files are stored in p3 directory and not having proper rights will not schedule the project, am i right.
cheers
mangesh
18 years 9 monthsRE: error message: Unable to create Temporary file
Hi Mangesh
