Compare with targets
18 years 1 month
Thanks guys,
Setting up new bars did the trick. Thanks!
18 years 5 months
Mangesh,
It shows % remaining of what??
P3 has remaining duration and res/cost percent expended.
It will show you the percent complete and not the % of work remaining.
REMAINING DURATION will show you the no. of days left and not %, while res/cost percent expended will show you zero value, if its not cost loaded.
Hope, i got ur problem correctly
ANYWAY, HAPPY BIRTHDAY DEAR.
Thought u must have gone on vacation. N’joi
18 years 6 months
hi
i am trying to use the column % remaining, it should show the % remain of the activity, but it shows zero, why it is so.
cheers
mangesh
18 years 5 months
Also,
Add columns TARGET1 EARLY START and TARGET1 EARLY FINISH, to compare the Target V/s actual dates.
Add one more column of VARIANCE to check the difference in the dates.
Ravi
19 years 7 months
Hi Brian,
First assign your target sch. (BASE) to the one u’ll be updating (PROG).
1- Open (PROG), click on "Tools" --> "Project Utilities" --> "Targets".
2- Select the (BASE) sch. from the drop menu - it must be located in the same folder as of your (PROG) sch.
3- Once selected (by pressing OK in the previous window), right click any where in the "Bar Chart" area, and click on "Bars".
4- In the window titled "Bars", click anywhere to add the Target bars (a window appears titled Add Bar Definition), type an appropiate desc. and choose the "Start point/End point" to read the "Target 1 early/late start/finish" by right clicking on the "Early start/finish" and selecting from the drop-down menu.
5- Set the size of bars and endpoints as u want.
6- In the "Add Bar Definition" window, set the position of the Target 1 bars to be #2 (located at top right).
7- Now the two bars should be appearing together in different positions (if the 2 bar sizes aren’t exceeding the row height).
HTH.
Karim
18 years 5 months
Hi Brian,
Could be a few things, check first that your row height is large enough and where you have the PROG and BASE you have nominated to be in different positions.
Cheers.
Karen
