Insert Logo in Primvera
18 years 9 months
sorry yaar there is a correction
Open a word file insert your logo in word , then copy it (Select All, Ctrl+C). Then open the pmt program, select new then paste it(select edit -paste). then save it the file is in pmt now
regards
deb
18 years 9 months
hi faizz,
I hope i told u , that u need pmt file .follow this-Open your logo in jpeg file..then copy it (Select All, Ctrl+C). Then open the pmt program, select new then paste it. then save....
HTH
Deb
18 years 6 months
hi
Sap syed
what service pack of p3 are u using.
coz i can import a .bmp file in my softwaare its service pack 3.
hope it helps
cheers
mangesh
21 years 2 months
Dear thankx for your repley . Still its not working . My Logo is .BMP file . Error Msg says that i have to convert to .PMT . How Can i do that .
22 years 6 months
Hi Syed,
You can insert logos in header/Footer & it can be either pmt, bmp, metafile or a word one.
If the desired location is elsewhere, use the insert function.
cheers
dattatreya
18 years 9 months
Hello i hope u want o insert logo at the bottom row , go to print preview, there u have footer , in footer select logo , which should be a PMT file.
regards
deb
18 years 6 months
hi
SAP syed
do one thing go to insert menu, click on object a window will pop up and it has all the other options by using which u can get ur task accomplished.
cheers
mangesh
