That depends on how you want to see the total percent complete , if u want to see in all the levels , then u have to select top in all the levels , if you want to see the total complete of the project then u have to select "top" only in the topmost level.
I am working on Pranab option to get a percent complete report for the project .when I go to organize in group by column I have Level 1, Level 2 and level 3.
Please let me know that in Total column do I have to select “Top” for all three levels(Level 1, Level 2 and Level 3)
22 years 9 months
Member for22 years9 months
Submitted by Alexandre Faul… on Tue, 2007-07-31 04:43
Ravi has answer your question in some sort, im in doubt if it meets your needs.
You need to present your report to expect the audience to undestand.
first,make a baseline in p3 as target, then decide what algorithm to compute % complete, is it physical, unit, or duration, allocate either MH or cost. the go to menu.. report > cost/resources,then print
19 years 1 monthRE: Project Percent complete
make sure that you understand how your Percent Complete was reckoned
18 years 9 monthsRE: Project Percent complete
Hello Zameer ,
HTH
Deb
18 years 5 monthsRE: Project Percent complete
Thanks for your help guys.
22 years 9 monthsRE: Project Percent complete
Zameer,
you should 1st create a wbs structure where Level 1 is the whole project,
then organize the layout to show the workbreakdown, and display the total for the 1st level
Alexandre
hello zameer,
Use format>organize>work break down , and then select Top in total , u should be getting the subtotal at the highest wbs level for percent complete ,
regards
deb
20 years 2 monthsRE: Project Percent complete
i hope it helps
regards.
For the overall project - percent complete, take the LEVEL 1 print-out. Its a part of monthly report submission in most of the orgzs.
In the percent complete column, it will show % complete.
In the footer, (If the finish date is not imposed) it will show the updated completion date.
