You cannot print A1 or A0 sizes by using PDF Printer, PDF Printer is used for converting any file to PDF file / format. So, First, you have to convert the page in to pdf format (Even it is in A4 or A3 size), and then try to print this pdf file in Plotter. When you choose the printer as Plotter, then click printing preferences. There you have to change the paper size, then you check the print preview.. If it is ok, then click print button...
There is noticeably a bundle to learn about this. I assume you made sure good points in features also. Levitra ballooner Viagra insolvencies Cialis Byway
18 years 9 months
Member for18 years9 months
Submitted by Pranab Kumar Deb on Tue, 2007-06-12 07:55
14 years 11 monthsHi,I use BullZip PDF printer
I use BullZip PDF printer and while printing i can choose the page size.
Amit Parmar
Check out my blog on Primavera at http://www.primaverablog.in
16 years 1 monthWell i use ABBYY PDF
Well i use ABBYY PDF Transformer 2.0 to make my own PDF's Files and this program let me select the size of the paper.
14 years 9 monthsHello, You cannot print A1 or
Hello,
Thanks.
ABDUL REHMAN
14 years 9 monthsThere is noticeably a bundle
18 years 9 monthsRE: How to print A0, A1 In PDF???
hello Amreshwar and Raviraj , for your great advice,
regards
deb
18 years 5 monthsRE: How to print A0, A1 In PDF???
Can try this also.
http://www.freeware995.com/bin/ps2pdf995.exe
Raviraj A Bhedase
21 years 3 monthsRE: How to print A0, A1 In PDF???
Hai!
Amreshwar Shukla
Thankyou for the address of such a usefull site address i was also searching for infromation on the same subject
Tankyou
Sridhar
22 years 6 monthsRE: How to print A0, A1 In PDF???
Dear Deb,
Download the free software cutepdf from "http://www.cutepdf.com/Products/CutePDF/writer.asp". It is free for personal and commercial use.
Then go to - Start-Setting-Printers & Fax- Then right click the cute pdf writer-properties-Device setting - Chose the paper size of your desire.
which PDF printer u r using by the way?
Hello Raviraj,
In paper size i cannot seee ISO A01 or any dimension more than A3 , please advice
regards
deb
Hi pranab,
Select the PDF printer you have.
In the paper size, select the ISO A0 / ISO A1 size.
(You dont have A0/A1, but you have ISO A01/A01)
And then just print it off.
Raviraj A Bhedase
