Adding Ramzan (Hourly) calender into P3
18 years 6 months
Hi Alex,
You are very correct if the total duration is in weeks then we should plan in hours e.g.shutdowns etc.
Ashraf
22 years 9 months
ashraf,
for sure planing the project in hours instead of days would be more simple, but it does not sound logical for every one to plan a 30 month project in hours, don’t you agree?
bqa 3ala kheir
Alexandre
18 years 5 months
Thanks Ashraf for the immediate response given.
This doesn’t work, but yaa as alex said i have to show every alternate day in ramdan month as non-working, which is not correct logically, but thats the only solution.
Raviraj
18 years 6 months
Hi Alex/Ravi,
Have you tried copying this project with HOURS as planning unit. I hope if it works the solution will be much simple.
Ashraf
22 years 9 months
Hi Ravi & Ashraf,
I have just given the same advice to one customer in Algeria: create a "Ramadhan" daily calendar where every other day is a nonworking day.
You can only create calendars with the same unit as the project planning unit.
mâa salama
Alexandre
18 years 6 months
Hi Ravi,
The answer to your question is NO you cannot add one more calender as planning Unit - HOUR, when you have already allocated calender with planning unit as DAY.
You can try making a Calendar with equivalent working days (3 instead of 6). This may help to some extent.
Ashraf
