The reason there is a different between the S-Curve (BQ in the table you see in the layout format) and the tabular report is because they use different baseline plan quantity.
I have this problem b 4, what you need to check is your target plan budgeted quantity and your current plan budgeted quantity. if they are different they will produce a different result between the tabular report and the P3 layout resource table.
22 years 8 monthsRE: Resource Loading Tabular Report
Hi John
If you can post your screen print, I might able to help
Alex
19 years 4 monthsRE: Resource Loading Tabular Report
The problem is probably because of changes on BC without changing Cost at Completion as well.
Means that you should have some Variance in your Cost or Qty...
Hi John
Long time no C, how are u!!
HTH
Alex
