converting from msp to primavera & vise a versa
24 years 6 months
There is a technical article on my web site that may assist you.
Paul E Harris
www.eh.com.au
23 years
See Earlier Posts On This Topic
There Are Several
Try This
Option 1.Use " PIPE"
2. Save As MS Excel File
Map Required Fields
Create A Blank Primavera Project
Export Schedule Data ’LOTUS’
Open This File With Excel
Copy And Paste required Datas
Import To Primavera
Make Sure Activity IDS are not duplicated
20 years 7 months
it should be installed with P3 as standard.
you can also access it from the C:\P3WIN\P3PROGS folder, look for a file called PRMCONV.EXE
18 years 11 months
Hey,
thanks for the reply.
but i dont have "mpx convertor utility" in my tool box. d i need to reinstall p3? is there any other way?
20 years 7 months
Hi there,
you have done it right so far, once you have created your .mpx file you need to open P3, and click tools, MPX conversion utility, click the MPX project to a P3 project.
in the convert project from window, select the folder and file where you created the mpx file, and select the mpx file, then click o.k, then it will ask you where you want to save your P3 project.
in order to convert P3 to Microsoft Project you just click the convert P3 project to mpx project when you are in the MPX conversion utility window in P3
Hope this helps
