How to Change WBS Sequence
22 years 8 months
Kelly
ANother dump way of doing it is export the WBS number
Delete the items that is out of sequencey
Add back the WBS item to the correct location
and Import back the WBS assignment
HTH
Alex
19 years 6 months
I guess I should have thought about it a little more but I should be able to create activity codes that mirror the WBS and then use the group/sort by function to get the order I want. Yes or NO?
Kelly
21 years
OOPS, that was the way you do it when you move from P3 to P5. There is NO way to change the sequence of the P3 WBS, other than the ASCII collating sequence (e.g. alphabetical order)
21 years
Use the "indent/outdent" buttons on the extreme right of the WBS screen. Any WBS sorted output foillows the sequence of the WBS that you create in the WBS screen
