How to remove pred & succ relationships with IMPORT ?
24 years 3 months
Hi Nicolas,
Good day! Yes, there’s an easy and effective way of deleting those unwanted relationship.
Follow these steps to delete specific relationship right inside your Excel (dbf or Lotus 123).
1). Export the successors relationship
2). Create a new column "in-between" the data columns.
3). Name the new column at Row 1 as DELETE
4). Type letter S at this new column to all those Activity
that’s causing your loop or those "unwanted" links.
If you want further details about this very useful steps, go to Help menu, and search "Delete data in Lotus 1-2-3 or dBASE.
Cheers Mate!
Jaime
22 years 5 months
If the suggested steps doesn’t seem to give you the result you expected then doing the conventional way would be the best way... that is to run and print a report of looping activities and then modify it one by one...
Cheers...
20 years 7 months
they are not taken into account.
quickest way to do this is this:
0. BACKUP!
1. export all of the relationships.
2. edit the relationships file as you like.
3. delete all relationships with global change.
4. import the relationships.
