Primavera Project Planner - P3 Member for 20 years 3 months Member for 20 years 4 months Submitted by Charleston-Jos… on Tue, 2006-08-08 01:04 Permalink RE: Convert to PDF format Hi, You can use primo pdf. Go to google, type primo pdf, then download the free version run the application, use primopdf your default printer now you can convert your p3 to pdf Cheers, charlie Member for 21 years 11 months Member for 22 years Submitted by Ganesan Sebrenmani on Tue, 2006-08-08 00:10 Permalink RE: Convert to PDF format Download CutePDF from goggle. its free. Member for 22 years 4 months Member for 22 years 5 months Submitted by Srinivasan Ramasamy on Tue, 2006-07-18 04:36 Permalink RE: Convert to PDF format Thanks for your replies Siva, Marcio & hans. I installed primopdf and now i can make pdf files. Member for 20 years 4 months Member for 20 years 4 months Submitted by hans HO on Mon, 2006-07-17 21:25 Permalink RE: Convert to PDF format Yes, but a PDF printer driver should be installed first. If u install a program like arcrobat reader, ther printer driver’ll be installed automatically. Regards. Member for 20 years Member for 20 years Submitted by Marcio Sampaio on Mon, 2006-07-17 20:11 Permalink RE: Convert to PDF format Yes, it is possible. See if u have a PDF creator on your PC. If u have, just print with PDF printer driver. Regards. Member for 20 years 4 months Member for 20 years 4 months Submitted by Siva Kumar on Sun, 2006-07-16 14:46 Permalink RE: Convert to PDF format It can be Done using PDF printer driver...U can print directly to rhis pdf printer and save as PDF file. Log in or register to post comments
20 years 3 monthsRE: Convert to PDF format
charlie
21 years 11 monthsRE: Convert to PDF format
22 years 4 monthsRE: Convert to PDF format
20 years 4 monthsRE: Convert to PDF format
Regards.
20 yearsRE: Convert to PDF format
Regards.
