Add a new custom data item with name NID (New ID) as a character. Then go to tools>project utilities>export, add a new and export "Activity ID" and "Activity custom data items" in WK1 format.
Then open the file with MS excel and copy the values from ID column to NID column, change them and then import the file in P3.
Finally run global change to assign the new IDs from the custom data item (Activity ID EQ NID).
yes.I tried to export to Excel and import again. However, some links were disconnected. I have check one by one and can not compare with original target programme coss the activity ID was changed.
Thank you for your suggestion.
Im only doing it one by one.
Have a nice holiday.
Fannie
23 years
Member for23 years
Submitted by george stewart on Fri, 2006-07-14 18:05
WCB.1.100 >>> WCB1100 by Global change Command, too?
The easy way to do this is to export the program to Excel, highlight the I.D. column. Go to find and delete "." then import the complete programme back.
Sorry if this is not in detail but am on holiday and do not have a copy of P3 with me.
If you do not know how to do this repost and ask for advice from Forum members.
regards,
Geo
19 years 5 months
Member for19 years6 months
Submitted by Praves Suppa on Fri, 2006-07-14 04:23
19 years 9 monthsRE: P3 - Gobal Change Command
Hi, Giannis Kostis
thank you.
I already tried. Export the data, such as ID, description and logic....Bla Bla. Establish a new programme by import that data.
unfortunely, few work sequnanec links are discounted. Work is failed. Eventually, I made it one by one.
Thanks & Cheers,
Fannie
20 years 5 monthsRE: P3 - Gobal Change Command
Hello Fannie,
FIRST OF ALL BACKUP YOUR PROJECT.
I ve just tested and works !
Hi George and Praves,
Fannie
23 yearsRE: P3 - Gobal Change Command
Change WCB.1.100
regards,
Geo
19 years 5 monthsRE: P3 - Gobal Change Command
Hi Fennie,
As per yr ACT Id hierachy I think u might take a little bit time to type the condition in Gloable change by..
VAR1 EQ SS(ACT,1,3)
VAR2 EQ SS(ACT,4,1)
VAR3 EQ SS(ACT,6,3)
VAR4 EQ VAR1 & VAR2
ACT EQ VAR4 & VAR3
But the problem is that u will have no room to put these data in Global Change
You might create CDI and store value for VAR1, VAR2 and VAR3
then you will be able to fulfill above equations
Good Luck
Praves
Hi, Praves.
can I trim Activity ID like that
Fannie
Hello Fannie,
I assume that you are going to trim the length Of Activity Id from 10 to 6 Characters..
Lets try to use function on Global Change by this condition..
DATAITEM | CRITERIOR | DATAITEM/VALUE
ACT | EQ | LEFT(ACT,6)
PLS BACK UP FILE BEFORE U DO OR CHECK THE TRIAL RUN BEFORE EXECUTE IT.
GOOD LUCK :-)
Praves
