Primavera Project Planner - P3 Member for 19 years 7 months Member for 19 years 8 months Submitted by Leo Nicholson on Thu, 2006-03-09 14:11 Permalink RE: P3 version 3.1 - The batch Is there any way to run PRMBATCH.EXE from command line with parameters? I want to run from within Clipper. For example: PRMBATCH.EXE test.txt where test.txt is: PROJ Q431 GENERATE USERNAME GENERATE ALL TEST INTO H:\TEST\Q431OUTx.TXT END Member for 19 years 8 months Member for 19 years 8 months Submitted by Paul Hutchinson on Thu, 2006-03-09 12:25 Permalink RE: P3 version 3.1 - The batch Ron, Thanks for the help. Any help on the other 3 points would be much appreciated. We currently use the CPM handbook for using Batch commands - but the SCHD was not amongst the commands. Do you (or anyone else) know of a "complete" listing for the batch commands? Cheers!! Paul. Member for 22 years 10 months Member for 22 years 10 months Submitted by Ronald Winter on Thu, 2006-03-09 11:11 Permalink RE: P3 version 3.1 - The batch Let me share with you the P3 batch CPM Calculation “SCHD” Card, Columns Remarks 1-4 SCHD 6-12 Data Date in DDMMMYY format 14-18 Time in HH:MM format (optional) 34 List Constraints (Y or N) 35 List Open Ends (Y or N) 36 List out of sequence activities (Y or N) 41 Allow external relationships to subprojects (Y or N) [Note: the next three are permanent] 61 Use Progress Override (Y or N or blank = N) 62 Use Interruptible Activities (Y or N or blank = N) 63 Compute float using (S=start, F=Finish, W=worse case) [Note: the next three are only in effect this run] 71 Use Progress Override (Y or N or blank = N) 72 Use Interruptible Activities (Y or N or blank = N) 73 Compute float using (S=start, F=Finish, W=worse case) 75-150 File name to save report (or PRINTER) blank=P3.OUT The easy way to read the current settings is with the card, PROJ xxxx LIST STATISTICS Log in or register to post comments
19 years 7 monthsRE: P3 version 3.1 - The batch
END
19 years 8 monthsRE: P3 version 3.1 - The batch
Ron,
Cheers!!
Paul.
22 years 10 monthsRE: P3 version 3.1 - The batch
Columns Remarks
1-4 SCHD
