Primavera Project Planner - P3 Member for 19 years 11 months Member for 19 years 11 months Submitted by vito Kooij, van on Fri, 2006-02-17 06:29 Permalink RE: Planned Value Management the data date is not a problem. you have2 work with your target BQ or you can use target variance to compare the original project and youre target. if you want 2 compare youre actual with remaining then use completion variance (Q) hopefully I have it correctly for what you wanted 2 do. Member for 20 years 3 months Member for 20 years 3 months Submitted by Edgar Ariete on Thu, 2006-02-16 14:32 Permalink RE: Planned Value Management How can you compare plans with two different data dates? Log in or register to post comments
19 years 11 monthsRE: Planned Value Management
20 years 3 monthsRE: Planned Value Management
