Global change & Replace
20 years 8 months
HI Mr Sung,
Global is the option with which, we can make certain changes which are common to all the activities or a group of activities in th eprogram,
For example, if you inserted a set of activities using fragnet and you wanted to change th eduration or activity id , you can can do it with global change,
Similarly Global change can also be used for assigningn resources to activities ,
By Replace what do you mean actually??
21 years
Global Change IS Replace..... but does that answer the question?
