Thats interesting - I tried Acrobat at 600dpi, instead of the default 1200dpi and it works ok. I then tried PDF995 again and noticed that it defaults to 600dpi. If I set PDF995 to 1200dpi it also fails to print all the details.
Interestingly, I have also tried it with an inkjet at 1440dpi and 11x17 and it does work ok.
So it seems that the limitation is at the P3 end of things, but does not apply to all drivers. I could confirm that if I had a printer driver for a 11x17 laser that prints at 1200dpi (the limitation does not show up at less than 1200dpi and 11x17).
Sean
20 years 3 months
Member for20 years3 months
Submitted by Hannes de Bruyne on Tue, 2006-02-14 03:25
I have same problem with the relationship lines. When I got the outputs, there is no relationship line for the first page. But after a second page and the other pages there are relationship lines. How can I correct it?
If you want to get rid of the Activity Description on barcharts, in P3, go to Format/Bars then for all visible bars click Modify/Labels -- remove the label.
Cheers!
20 years 5 months
Member for20 years5 months
Submitted by Eckart Schenck on Thu, 2006-01-05 01:00
24 years 4 monthsRE: PDF Limitation?
Sean
20 years 3 monthsRE: PDF Limitation?
Other suggestion : if possible use 300 dpi instead of 600dpi
Regards Hannes
Thanks for the suggestion Charlie. I will keep it in mind if I have trouble with pdf995, which is working just fine so far.
Sean
Sean
20 years 4 monthsRE: PDF Limitation?
Hello Sean,
You can use primopdf.
It is also a free download from the internet.
So far, i have no problem using primopdf.
Charlie
20 years 2 monthsRE: PDF Limitation?
Cheers!
20 years 5 monthsRE: PDF Limitation?
Im using PDFfill (see www.pdffill.com).
Free software, easy use, no adverts.
cheers
I tried it and it appears to be working.
Thats pretty amazing for $0.00.
Sean
22 years 5 monthsRE: PDF Limitation?
Hello Sean
Try surfing Software995.com then you can download a demo pdf995 and see if this will work for you.
HTH
Christian
