What I normally do is to save a copy of the levelled schedule as a target schedule for later reference.
In addition, the reason that you don’t really need to keep the schedule becasue each time the senario changes you will need to re-level your schedule base on the new conditions. What you however need to save is your levelling setup.
Priority, Float control...
HTH
Alex
20 years 6 months
Member for20 years7 months
Submitted by Zhang Haixiang on Wed, 2005-11-09 20:57
I agree with Ronald. Creat a custon data item to store leveled date for reference.
and be careful using constraints. After updating your schedule, youd better re-schedule and re-leveling, because critical path/total float/free float may change, the result of leveling will also change.
22 years 10 months
Member for22 years10 months
Submitted by Ronald Winter on Wed, 2005-11-09 10:56
It is easy to remember scenarios. Create Custom Data Fields for the Early Dates and then use global edit to transfer the leveled dates into this new field. Done! Good luck.
23 years
Member for23 years
Submitted by Hemanth Kumar on Wed, 2005-11-09 05:47
22 years 8 monthsRE: levelling of resources
Echo.......................
Back to the original question
HTH
Alex
20 years 6 monthsRE: levelling of resources
Sunil,
22 years 10 monthsRE: levelling of resources
23 yearsRE: levelling of resources
Not Possible My Friend
Levelling gives scenarios
if you want to retain dates note it down and constrain activities
