I guess this thing cant be generalised. It depends on the scenario.
1) If the changes are addition in scope, it could be worthwhile to come to an agreement with client and incorporate the additional scope.
2) If the changes are to the durations and relations of the existing activities it depends on how you want to go about it. Either you leave your baseline as it is and change the current project only in which case you are not comparing apple to apple.
or you discuss and decide to revise the baseline so that when you are tracking the progress, there is difference in the durations and relationships in target and current project.
One has to really see what suits your project.
19 years 9 months
Member for19 years9 months
Submitted by dinishwar singh on Mon, 2006-01-23 07:18
this is standard with p3, however i tought there was a way to get around this.
meaning , if there is a folder with all the current project p3 files and the target p3 files , if the target files for that project were deleted and an attempt to open the current project files gives the above error "Target project not found"
22 years 5 months
Member for22 years5 months
Submitted by Christian Adri… on Sun, 2006-01-22 13:05
you could go to file> Project overview> select the tab "Target" then remove the target file that was already been deleted... then open your current project and see if it works..
HTH
Christian
19 years 9 months
Submitted by dinishwar singh on Sun, 2006-01-22 11:02
It’s nice to know that you are already interested in planning. But it seems that you have a long way to go. So, if you’re really into it why not just REREAD the thread and find the answers to your questions?
Sen
20 years 3 months
Member for20 years4 months
Submitted by Edgar Ariete on Mon, 2005-11-14 11:53
Isnt your target your original plan? And everything you are trying to figure out is within that plan? Then how are you going to realise that? Create your current plan & compare where?
Performance can be measured and monitored in two ways: by SPI (Schedule Performance Index) and by CPI (Cost Performance Index), also known as Earned Value Management or EVM. In SPI you compare Planned Schedule vs. Actual; while in CPI you compare Planned Cost (or Resources) vs. Actual.
20 years 3 months
Submitted by Edgar Ariete on Fri, 2005-11-11 08:24
If your resources is more than Planned, you can either increase the Resource or the Duration. In either case, you will be OVER BUDGET (accept this!) because your planned budget is not enough or the planned productivity is high and your actual productivity is low.
If budget is your concern is Budget, you should have a higher productivity than planned. That is, pressure the men and make the equipments do more work at site. This however will be the PM’s job, not yours.
1. If my resources exceeds than what i planned ( consider the type of activity is task) then i have to change it in resouces or not... coz my budget is going to increases...
I mean once i created a target file( baseline of current schedule) whatever i do i have to do it in currrent schedule ?? Am i right????
Yes, you are correct.
In P3, the current schedule is kinda your working file. Changes, progress updates, revisions, etc – you do it in Current Schedule.
If i had to update my target file i have to do it from update command????Am i correct...
Yes, you’re correct again BUT “be cautious in choosing the update options” (Tool/Project Utilities/[Select Target]/Update) – if you’re not careful, there’s a possibility that your Target schedule might be made equal to the Current Schedule (unless you’re progress is on schedule). In this case always keep a back-up copy of your target file before updating it.
Another way, and it’s the safer way, is to open the Target file separately. Make a copy or back-up file. Then, do the updations on the copied Target file. Once the copied Target is finalized and updated, you can now replace the existing Target of your current schedule by the Updated Target.
Again, a reminder: DO NOT UPDATE TARGET (or Baseline Schedule) UNLESS NECESSARY.
Sen
20 years 3 months
Submitted by Edgar Ariete on Thu, 2005-11-10 12:57
If you have read the whole thread I certainly hoped that youve gotten the whole picture... you never update you BASE programme (unless your going for a revision) only the CURRENT programme (for schedule comparison)...
HTH..
Christian
20 years 6 months
Member for20 years7 months
Submitted by Zhang Haixiang on Wed, 2005-11-09 20:45
It may be that at some time the change to the plan is so significant that the client wants a new baseline to measure the Plan against (... am waiting for Clive and Oscar to wake up and shout at me...). In this case, make a copy of your first Baseline, assign that Copy as Target1 (with a new title e.g. Revised Baseline..) and update changes on Baseline through your working programme.
Note: This exercise is really only for when Snr Mgmt or the Client request a Change to the measurement Baseline. You must still maintain the original Baseline for Reference or in the event of Claims etc.
22 years 5 months
Submitted by Christian Adri… on Wed, 2005-11-09 05:48
Theres no need for you to update your target file (Baseline of your current file) coz thats the original plan from the time you have submitted it to your client (if have submitted and accepted by your client), if you have to make some changes then do it in your current file (just like what Zhang said..),as this should reflect all the progress of your project..
Just to add some thought..
Christian
20 years 8 months
Member for20 years8 months
Submitted by Sukumaran Suba… on Wed, 2005-11-09 02:53
19 years 5 monthsRE: Regarding Target file
19 years 9 monthsRE: Regarding Target file
thanks christian, got my files to open
hello christian
not getting to open the project at all..
message "Target project not found"
22 years 5 monthsRE: Regarding Target file
Dinishwar,
HTH
Christian
Good Day
my target files were deleted and i want to open my current project, is there anyway i will be able to do this
20 years 3 monthsRE: Regarding Target file
Sen,
Best regards too.
20 years 2 monthsRE: Regarding Target file
Edgar,
Sen
Ok Sen,
Ok, Edgar. The subject will now shift a bit…
Sen,
How do you consider performance as actually planned? And things that turned out not the way you planned it? I mean how do you compare both?
Sunil,
Sen
20 yearsRE: Regarding Target file
Sen
That was a nice explaination.. thanx alot....
i had a query regarding tracking
where i have to do changes???
Sunil,
Here’s a direct answer on your post No.3:
Sen
Guys,
Where are you now? Are you ahead, or behind? Or are you working on your recovery plans?
Oh, by the way, there are 10 variations coming up.
That’s why in P3 you are given the chance to create two (2) Targets.
Target 1 – you can store the original baseline schedule (as per contract).
Target 2 – you can store the revised baseline schedule or your calculated schedule during the previous updating period.
And there’s another way to add Target 3, if Target 1 & 2 were already utilized, by using Custom Data Items.
Sen
Hello Edgar,
HTH..
Christian
20 years 6 monthsRE: Regarding Target file
Sunil,
for upadating target, you can use update command,or you can open the target file and make changes
Sunil,
for updating target,
Christian,
If youre not going to update your target plan, how are you going to compare it with your current plan? (i mean in terms of physical progress)
thanx alot!!
Sunil,
I agree wholeheartedly with the above.
Just one more thing to offer:
Sunil,
Christian
20 years 8 monthsRE: Regarding Target file
Sunil,
Have you submitted the baseline schedule to your consultant.
a) If Yes! Then your updated target schedule become your Revised Baseline Schedule. Submit to consultant for approval.
b) If No! Update the target schedule and submit as a Baseline Schedule to consultant for approval.
Regards.
Its up to you. Do you want to include this change in target?
target is a baseline for comparison with current schedule.
If you want to show this variance then change current schedule, otherwise change both target and the current
