Primavera Project Planner - P3 Member for 22 years 8 months Member for 22 years 9 months Submitted by Alex Wong on Sun, 2005-11-06 20:03 Permalink RE: No Subject Specified Or as Philip suggested using hammocks is your only way out However, it involved a lots of work Good luck Alex Member for 20 years 2 months Member for 20 years 2 months Submitted by Sen Moc on Sun, 2005-11-06 19:58 Permalink RE: No Subject Specified Kumar, Create dummy activity codes (or use your existing codes). Then choose whatever color you prefer in Format Bars/Pattern. This is the only way your problem will be solved! Regards, Sen Member for 22 years 8 months Member for 22 years 9 months Submitted by Alex Wong on Sun, 2005-11-06 18:36 Permalink RE: No Subject Specified Cannot unless you are using P3e teamplay or P3e/c Member for 23 years Member for 23 years Submitted by Hemanth Kumar on Sat, 2005-11-05 12:01 Permalink RE: No Subject Specified Not Possible ,,,thanks to all Member for 21 years Member for 21 years Submitted by Philip Jonker on Fri, 2005-11-04 14:50 Permalink RE: No Subject Specified You have lost it Member for 22 years 4 months Member for 22 years 4 months Submitted by Shahzad Munawar on Fri, 2005-11-04 14:30 Permalink RE: No Subject Specified Not possible so far Member for 23 years Member for 23 years Submitted by Hemanth Kumar on Fri, 2005-11-04 13:11 Permalink RE: No Subject Specified Not Possible ,Pattern Will Give Color to coded activities Only Member for 20 years 2 months Member for 20 years 2 months Submitted by Sen Moc on Mon, 2005-10-31 01:05 Permalink RE: No Subject Specified Question: Is it possible to give another colur to the summary bars (sub total bars)?(/i> Answer: YES. Go to Format Bars/Pattern. Cheers! Sen Member for 23 years Member for 23 years Submitted by Hemanth Kumar on Sun, 2005-10-30 02:11 Permalink RE: No Subject Specified hammock cant show real summarised % complete Member for 21 years Member for 21 years Submitted by Philip Jonker on Fri, 2005-10-28 13:43 Permalink RE: No Subject Specified Then try using hammocks, which you can format Member for 23 years Member for 23 years Submitted by Hemanth Kumar on Fri, 2005-10-28 11:02 Permalink RE: No Subject Specified dear peter you cant format summarised bars Member for 20 years 2 months Member for 20 years 2 months Submitted by Peter Bailey on Wed, 2005-10-26 16:24 Permalink RE: No Subject Specified Try format - bars and then change the colours as you like them Log in or register to post comments
22 years 8 monthsRE: No Subject Specified
Good luck
Alex
20 years 2 monthsRE: No Subject Specified
Kumar,
Sen
23 yearsRE: No Subject Specified
Not Possible
,,,thanks to all
21 yearsRE: No Subject Specified
You have lost it
22 years 4 monthsRE: No Subject Specified
Not possible so far
Only
Question:
Answer:
Cheers!
Sen
dear peter
