Beg to differ, but hammocks and group summaries show the elapsed duration i.e from the earliest early start date until the latest early finish date, not the sum of the durations.
Try using the $tmp functionality in Global change, or use Excel.
HTH
20 years 8 months
Member for20 years8 months
Submitted by Sukumaran Suba… on Tue, 2005-08-02 04:03
u can go to > format >organize >and there is a form "Group By" , so u can see total, click on that box, there is option top or bottom, then organize ....u can see the result.
but i dont understand your question, what to do with global change...? can u explain on that so i can help....
I tried it (CDI) but not worked because the variable assumes the value of OD on each Activity and not the sum of all OD. Did you understand ? I need the sum of all OD and store this sum in a variable that i can use in a global change.
20 years 1 monthRE: How can i store the sum of OD in a variable ?
hi
creat a dummy resource for ex.(durn)
by global change let it equal to od then organize by resource or deal it as u want
20 years 10 monthsRE: How can i store the sum of OD in a variable ?
Hi Suku,
Go to - Help - Global change- Temporary variables.
It is explained better with 2 examples .
HTH.
20 years 8 monthsRE: How can i store the sum of OD in a variable ?
Attach is the sample for your review.
Regards.
Nilo,
First
Go to: Custom Data Items > Activity tab and create Sum Orig Dur (SODR) and type as N (Numeric).
Second
Go to: Global Change > Change tab > Then: SODR=EQ=OD and Run.
You will get the duration for each individual activity and the total duration for each coding.
HTH.
20 years 3 monthsRE: How can i store the sum of OD in a variable ?
Thanks all !!!
But i don´t want use Excel. I wanna do it into the primavera.
Thought Nilo is asking for the subtotal/total figures as appearing on summary bars. Anyway, what is your feedback Nilo?
Steven, I couldnt find &tmp in P3 help. What is the full name of the function?
Regards.
23 yearsRE: How can i store the sum of OD in a variable ?
Sorry, I remember now its &tmp. Look in the help
Excel would be the best way of doing it.
Steven could u tell me more about $temp functionality.
Thanx.
HTH
Use Hammock activity. The function is same like subtotal bar. It will give the sum of OD for each grouping. Then you can store it as CDI.
Regards.
20 years 5 monthsRE: How can i store the sum of OD in a variable ?
dear Mr nilo
cheers
22 years 8 monthsRE: How can i store the sum of OD in a variable ?
Are you sure u dont want to try this outside P3 ? Trying to Subtotal the grouping by activity codes in Excel could be one alternative.
Also try looking at Resources if CDI dont serve your purpose.
Thanks !!
Perhaps you could try to store it as a Custom data item or as a Resource.
Mary
