Basically, Retained Logic is the preferable method. The planner still can use Progress Override to schedule the work programme but after every update he/she need to do some homework, i.e. link all the out-of-sequence activities to the nearest logical successor (FF + lag or FS +/- lag) to minimise/control the large positive float.
Regards.
22 years 11 months
Member for23 years
Submitted by Steven Oliver on Wed, 2005-07-20 08:40
IMHO, generally the retained logic option should be used. However there are occasions were operations are not directly related to each other, but all need to be done before moving on to the next stage, and progress override can be used.
It is really up to the skill and knowledge of the planner to decide, there is no definitive answer.
HTH
20 years 10 months
Member for20 years10 months
Submitted by Shivaji Nagare on Wed, 2005-07-20 06:09
20 years 10 monthsRE: Total Float
Thanks Sunil...
It cleared all my confussion on scheduling option..
Thats why i tell all my friends to visit Planning Planet...
Cheers I am Happy...
Shiva
20 years 7 monthsRE: Total Float
Guys,
Check this site www.HTCProjectcontrols.com Eric gives a splendid explaination on this topic under Solution Bulletins.A must see site for all planners.
Sunil
20 years 8 monthsRE: Total Float
Steven you are right.
Regards.
22 years 11 monthsRE: Total Float
HTH
Yes Suku
I did it. and it gave logical float.
What should be normaly done? I mean scheduling with progress overide or Retain logic?
Any way thaks..
Shiva
Shiva,
It is because of Progress Override. When you choose Progress Override, P3 ignores network logic and allows the activity to progress without delay.
So, change the calculation mode to Retained Logic and reschedule your work programme. You will get the logical float.
Regards.
