Maybe I am not quite understanding your query, but here goes. When you were setting up your codes/values/descriptions there is a column on the left showing order. You use this to show the sequence you require by numbering from 1,2,etc.
This will then allow you to achive your requirements.
20 years 5 monthsRE: Simple Grouping Query
Thanks George / Zhang
Worked a treat !
JP
20 years 6 monthsRE: Simple Grouping Query
George Stewart is right. you can also set up activity code for sorting (eg ORD1,ORD2)
23 yearsRE: Simple Grouping Query
Hope this helps,
George
