Can anybody send me latest version of PERVASIVE Driver.
When i installed ver 2.04, I am getting a message "Login must succeed before data source entry can mbe written" (Status code 802). Please advice,to rajesh_m@walla.com
Rajesh M
21 years 5 months
Member for21 years5 months
Submitted by Rajesh Moolakkandam on Sat, 2005-11-12 01:01
I dont think it is a good to update P3 file using Access. To do this you need a very clear understanding of P3 data structure,otherwise you will input some invaid data,and make your file corrupt. I suggest to use RA instead, because RA will do some basic data checking. I use Access (informaker) & OBDC only for reporting, because they can generate more professional report than P3.
For your task, you do not need to make it so complex.
Just make a query in Access to include Act ID, Act Dur, rem dur ...what ever you want, then save this query as a DBF file, and then import it to P3. Make sure the field length is the same as P3 expected (e.g. description 48 char...)
But Im finding difficulty in updating activity data in Access and transfering those changes back to P3.
Ive created the Access tables as Linked tables (rather than Imported), but when I change the data - Access tells me that:
"Write Conflict
This record has been changed by another user since you started editing it. If you save the record, you will overwrite the changes the other user has made.
Copying the changes to the clipboard will let you look at the values the other user entered, and then paste your changes back in if you decide to make changes."
It doesnt give me an option to "Save Record" (the option is disabled), just "Copy to Clipboard" or "Drop Changes"
So I just cant do what I want to do.
Any advice?
21 years 9 months
Member for21 years9 months
Submitted by Daniel Jeyaraj… on Sun, 2005-06-05 23:16
The file is on the way to your inbox. Approx. 2.5 MB or so, it has to cope up with our internet traffic......so soon you will receive it(may be in another 20mints time???).
I installed that file into the P3-menu item. At the first click on it it was complaining that the Pervasive driver was not installed. I then tried to install the driver thru the windows configuration program as I tried a dozen times before and this time I succeeded to go past that point where it broke off the installation all previous times.
So I can now import those DDF files into Access very easily, thanks to you mate.
Marcel
24 years 6 months
Member for24 years6 months
Submitted by Frank Borcherdt on Mon, 2005-05-30 05:02
Assume you have P3 3.1 installed on the same machine so you have the btrieve microkernel files as well as the ODBC drivers.
I just loaded the ODBC drivers and was able to link and retrieve data using MS Access 2002 SP3 and an XP Pro SP2 machine with all Micrsoft critical patches loaded.
I used the P3 ODBC Manager to create the ODBC datasource.
Find at http://www.ecspl.com.au/support/odbc Copy to P3WIN folder, run it once without P3 running to add tool to Tools menu and then you can run from Tools menu in any open project to create the ODBC source.
21 years 5 months
Submitted by Marcel van der Leij on Mon, 2005-05-30 02:14
I recently tried to install the Pervasive od32v204 driver on a Windows XP computer, however I can not get beyond the point where you enter the path of the DDF directory.
When closing the window in order to return to the ODBC Data Source Administrator, the following error message appears :
"Login must succeed before data source entry can be written. (statuscode 802)"
Of course the directory exists and contains the 3 Primavera DDF files. I also tried to enter the directory with the demo DDF files installed by the driver, with no success either.
Could any of you guys point me in the right direction?
Marcel
24 years 6 months
Submitted by Frank Borcherdt on Mon, 2005-05-30 01:02
Whilst ODBC does work it is much better to use Ra the P3 Object model mentioned by Dayanidhi if you intend to update P3. ODBC is great for reporting.
ODBC does not reference the business rules (autocost rules) and you need to perform ALL of the associated updates the P3 performs when you manually enter the data...if you miss some you will end up will data that does not make sense.
The Ra object model automatically does this for and can be found on you P3 CD.
Certainly you can link MS Access to P3 using ODBC. Infact you can write your own programs using VBA in Access to communicate with P3 Objects and customize the things in your own way.
21 years 5 monthsRE: Link Ms Access to P3
I believe that you do have the latest version.
I had exactly the same problem, read my previous posts and the solution offered by Frank Borcherdt in this same thread.
Hello friends,
Rajesh M
Hello friends,
Rajesh M
20 years 2 monthsRE: Link Ms Access to P3
Daya,
Can I have a copy of pervasive too?
My email is whaboub@yahoo.com
Rgds
W.H
20 years 6 monthsRE: Link Ms Access to P3
Daniel,
24 years 9 monthsRE: Link Ms Access to P3
So we now know how to link the data.
"Write Conflict
Any advice?
21 years 9 monthsRE: Link Ms Access to P3
Daya,
My email is rhesan@yahoo.com
Rgds
Daniel
21 years 2 monthsRE: Link Ms Access to P3
http://www.eh.com.au.
Have got a detailed method.
This has Also been discussed before will find the link is
">http://www.planningplanet.com/forum/forum_post.asp?Cat=2&Top=7181<?a>.
Please have a look at Daya Explanation it is a good tip for
20 years 7 monthsRE: Link Ms Access to P3
Gentlemen,
I have the ODBC and the Pervasive (Thanx Daya), can someone suggest a step by step way of linking p3 access. Would greatly apprecaite it.
Thanx
Sunil
Thanks Daya,
Since I have High speed, i think it shouldnt be a problem
Sunil
22 years 7 monthsRE: Link Ms Access to P3
Sunil,
Cheers!!!
Daya
Hellow Daya,
Awaiting your attachment with excitement.
Sunil
Alex, Its my pleasure to help others.............
22 years 8 monthsRE: Link Ms Access to P3
Daya
It seem that you becomes the favour of the months
Alex
Hellow Dayanithi,
Please Can I have a copy of pervasive too. My email ID is rsunilr1@yahoo.co.in
Thanx
Sunil
Don, Leave me your email id to send the file or contact me at plannerdaya@yahoo.com
22 years 5 monthsRE: Link Ms Access to P3
Gentlemen where I can get this Pervasive Driver.....
Frank,
Marcel
24 years 6 monthsRE: Link Ms Access to P3
Guys,
Marcel
Daniel,
Sunil
Yes MS Access work very well with P3 using ODBC. Of course you need to be a programmer if you want to make it more user friendly.
Alex
Hellow Dayanidhi,
Have you actually tried it and is it working perfectly ???
All,
Thnaks for the reply. Will check the link.
Daniel
20 years 11 monthsRE: Link Ms Access to P3
Daniel,
Check this thread
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=2&Top=64.
Daniel,
HTH
Daya
