The problem is probanbly, that when you created the target bar you did not set the required dates ti target 1 or 2 dates. Rightclick on the barchart area, then on Bars..., then on the target bar, and then on modify. Check under type that you have sppecified target 1 early start and finish.
21 yearsRE: target bar doesn’t freeze
It is because he had early dates specified for the target bar, and not the target dates.
20 years 7 monthsRE: target bar doesn’t freeze
Philip,
Is it a problem due to not saving as target project while the project is open?
Just for my understanding.
20 years 5 monthsRE: target bar doesn’t freeze
Thanks Philip
It solved my problem.
Grazie
L.
Hope this helps
