Close P3. Next Install the Cute PDF Writer software.
Next set the Cute PDF Writer as the default printer in Windows (Settings/Printers). Next open P3. Next open your P3 project. Next print your required layout and it will print to PDF format.
23 years
Member for23 years
Submitted by Steven Oliver on Tue, 2005-05-10 06:44
20 years 5 monthsRE: export from P3 into PDF
There is a freeware solution which I have used and it works fine in creating PDFs from P3 (or any Windows application).
It is called Cute PDF Writer, available free from:
http://www.cutepdf.com/Products/CutePDF/Writer.asp.
Here are some instructions which I hope help:
23 yearsRE: export from P3 into PDF
You need a pdf writer. This then appears in your list of printers.
The most popular is Acrobat which you have to pay for, alternatively there are a number of freeware/shareware solutions available.
HTH
Sorry Guys
I found it in the forum.
It works
thanks
RE: P3 convert to PDF file
Aleli Florencia Marquez,
I’ve had similar problems when printing to PDF.
You need to make PDF the default printer first and then print in the normal way.
Another P3 Idiosyncrasy.
