Trade Filter
21 years 1 month
Philip
your answer open the thought, but still if you would elaborate with example and how can open the code from the p3 etc will be more helpful
Azvi
21 years
Hi Azvi,
It is simple, create a resource code for each trade, and add the resources to the program, eg Resource CONC is concrete work, FINI is finishes etc. Then run s-curves for each resource, this will give you what you need.
20 years 8 months
Why you want to export the activity.
You can do from Schedule itself ,Create column Planned % ( Baseline at datadate -Updated % ) Actual% (% completion ) in schedule Itself . Take Print out, If you don’t want Bar chart ,Tick off the Option.
You can summarised this Schedule as report. I don’t think any problem.
23 years
If you set up a new export file, then filter your selection and use the target % complete and actual % complete. run this and you will get the results required.
See Tools, Project Utilities, Export. If you require more help come back
George
21 years 1 month
I intent to produce report for each trade progress
exp:
Planned% Actual% Slippage
Earth work ----- ----- ----
Concrete work ----- ------ ----
Finishing work ----- ------ ----
21 years 3 months
Could you eloborate your question? What exactly you want to do?
