If yes does your current forecast reflects the same dates as per the extension of time. (The extension of time should be an contract ammendment)
If no why not. Remember you can only reqeust an extension of time for the owner delay portion ??. I have found it easier to show this on the original target schedule because this stop all arguments about who is to blame for the delay. What is nice about it it will show you exactly what infuance it has on your Original critical path.
If you want to use your time now schedule you must use your forecast at the time of the increase of QTY. Not at the time after the extension of time.
AS an example
Your schedule say a 10 weeks for an activity.
On week 3 the QTY is increased and your new forecast date is the extension of time.
On week 5 Progress is delayed by the contractor.
On week 7 the extension of time is granted. And you submit your current forecast as the new target. The Consultant will argue that week 5 is due to the contractor and not the increase of scope.
On what dates must the extension of time be based on week 3 / 5 / 7 ????.
The answer is very simple as per the extension of time. That is why all the contract I am used say you have 7 days after the event to notify the engineer for an extension of time.
Please note that these are the baseline dates that should be used in your target schedule.
22 years 7 months
Member for22 years7 months
Submitted by Dayanidhi Dhandapany on Wed, 2005-02-02 12:03
In my opinion, you have to use the updated schedule, just for an example,UD10 for which you had obtained EOT from the client as your target schedule, name the UD10 as a convenient target file name, like BA02 or TA02 so and then use copy of the latest updated schedule may be UD14 or so name it as UD15 to continue your update for the next month submission which will be having a target file of BA02 or TA02.
HTH
Daya
24 years 5 months
Member for24 years5 months
Submitted by Roger Gibson on Wed, 2005-02-02 10:14
21 years 1 monthRE: Revision in target schedule
It all depends wat your contract say.
Have you received an extension of time ?.
AS an example
22 years 7 monthsRE: Revision in target schedule
Dear Anil,
HTH
Daya
24 years 5 monthsRE: Revision in target schedule
Anil,
In my view, you should submit a revised schedule showing only the remaining works to completion, including the additional work.
Roger Gibson
