Import Project codes?
16 years 9 months
Hi there Andrew,
We have tweaked the code so that it will (hopefully) show the slash, i.e. the \\\\\\\\\ character.
Thanks for the observation.
PP Admin.
20 years 11 months
This forum doesn’t support slash symbol.
20 years 11 months
Go to debug mode and check the vba code. I’m pretty sure that something wrong with project path or project name.
Be aware - you have to put short path in any Macro.
For instance:
c:progra~1 instead of c:Program files
Don’t hesitate to contact me personally.
Andrew
22 years 6 months
Thanks. But I get an error 501111, file not found. Any ideas?
Thanks once again.
20 years 11 months
Hi, there
Make sure P3 is already running on your computer (even with no project opened). That may help.
22 years 6 months
I checked the spreadsheets. For the spreadsheet to work is it necessary that p3win directory exists in the C directory or will it work even if the p3win directory exists in any other subfolder in the c: directory. It just displays exiting RA as soon as I run any macro.
Can anyone help?
21 years 2 months
D:SUPPORT/UTILS/EXCEL/activity
Will give you the ability to import Codes & Descriptions from xls
22 years 9 months
Guys,
I am looking for a way to import PROJECT CODES from some Excel or Lotus 123 file to P3.
It looks like it’s only possible to export / import activity / resources custom data items.
Any idea?
21 years 2 months
D:SUPPORTUTILSEXCEL
ACTIVITY
This will allow you to export/import the Code & Description. If you jou want to assign act codes to an activities you can just export a norml wk1 file and ensure that you have ask for activity id & activity codes
23 years
I dont recall the name of the file, but they are *.xls, with macros written to import/export activity codes, resources and WBS.
22 years 9 months
Hello Steven,
I only have an evaluation CD; what i sthe name of the file, I’ll have a look
Alexandre
23 years
Supplied with P3 are some utilities to do exactly this. If you dont have the original CD, PM me and I’ll forward a copy.
