Q 1) While closing current layout and opening other layouts, It asks Filter has changed…. Do you want to … Yes / No… what is this ?
Ans: If you do any changes to the opened layout(current)in the filter or summary options or organize area, it will ask you to save it to the current settings(when you close P3 application or opening another layout) if your answer is no to this question, the previous settings of the opened layout(current) will be preserved and whatever modifications has been done so far to the current layout settings(filter, organize, etc.,) will be lost(not the data).
2) I keep standard 2~3 Layouts in the backup and use them for printing final updated schedule for client. The problem I face here is, I need to open each layout and change the revision. Is it possible to change Title and Revision Box of all layouts when we edit page set up of current layout.
Ans: If you pick the items like [Project Name],[Project Title], [Layout Name] from the drop down list, you dont need to change the layout names as and when you save it, it will be updated as per your given layout name automatically. In the sameway you can look for default items. But for Revision Box, i could not see a way to make changes in one layout that can be appeared in all layouts, the reason is simple, there is no default insertion option in the revision box area.
My current practice is specified a layout name as my current working. Once I achieve a critical display effect, I will do a Layout Save As (in a final name).
So I always work on the current, the Save As will be used only for reporting.
22 years 7 months
Member for22 years7 months
Submitted by Dayanidhi Dhandapany on Sat, 2004-12-11 02:50
To avoid this kind of situation, you have to create a layout called backup layout(or name the layout at your convenience)and again save a layout called current layout. Then you start working on current layout, if suddenly someone closes your system during your absence and lost your current layout settings, still you can have a choice to open your backup layout and again save it as current layout(remember to set the layout number to be the same as your previous "current layout" number or else it will create a same title (current layout) with next layout number(when you want to refer the current layout at later stage you might be confused to see the same "current layout" names twice with different layout numberings)
the other option is delete the previous layout called "current layout" and open the "backup layout" save it as current layout and start working on the current layout.
(Note: Philip has meant to say the same in a few words, just ive elaborated it for you)
Daya
23 years
Member for23 years
Submitted by Hemanth Kumar on Fri, 2004-12-10 10:55
It is fairly simple, go to view/layout/save as, save your current view, then save as a new view, when this is done go back to your previous layout which will be the same. If you make any changes the layout will still be saved under the new layout you saved. Hope this helps.
23 yearsRE: lay outs
thanks to all
now i create 2 layouts
one master-one slave
22 years 7 monthsRE: lay outs
Dear Gangadhar,
HTH
Daya
23 years 8 monthsRE: lay outs
Dear Hemanth,
I have same practice as Dayas suggest.
Dear Hemanth,
Daya
friends
my problem was this
when somebody closes the p3 project there is prompt-"save current layout?"
for non p3 users the answer is "yes"...means my lay out is gone
20 years 11 monthsRE: lay outs
Hi, Dragos!
This way is not so simple as it looks like because P3 locks all active project files i.e. you cant copy any of it to another location :-(
Hi Hemanth,
I believe there is no way to recover your previous settings of the layout lost, follow Philips advice that is a valid one.
Cheers!!!
Daya
21 yearsRE: lay outs
Hi Hemanth,
Philip
