I have had a closer look and I agree with you, it still calculates over the activity calendar. My apologies for giving you wrong advice.
What needs to be done is to convert a dates into workperiod numbers as integers and subtract them.
I have had a look at a few manuals and I cannot see a way unless the activity is on a 7 day per week calendar.
So what you may try is running a Global Change to change the activity calendars to a 7 day per week, saving the original calendar say in a CDI and then calculate the variance, then change the calendar back before recalculating the schedule. In my test environment I had to run one change to change the calendar and a second to calculate the variance and change the calendar back. It did not recognize the calendar change when I tried it all in one global change and I was using CDIs as dates not a Target Project.
This is a bit of messing around to set up but it may work.
Paul E Harris
I think you are subtracting one Custom Data Item Date from another Custom Data Item Date which will calculate over the calendar of the task.
The global change is must use temporary values say &D1and &D1 which are not writen to the database and therefore are not associated with a calendar:
Eg the Global change should be:
&D1 = EF
&D2 = T1EF
DIF = D1 - D2
Don’t forget that P3 uses day numbers not the current time so you will have to add another line to add one day to the result with an extra line in the global change to get the same answer as Excel:
DIF = D1F + 1
Paul E Harris
If you use Global change and copy the two dates you wish to compare into two temporary fields, say &T1 and &T2, then subtract then on the third line of the global change and put the result into a CDI (Custom Data Item), the resulting calculation will be in elapsed days.
Paul E Harris
Its easy to do if youre familiar with MSAccess or Excel (MSAccess is better IMHO). Just make one Custom Data Item (Numeric, say DIFF for instance) Export from P3 ActivityID, early and late dates for current & target projects and Activity Custom data items to DBF format then open this file either by Excel or Access.
Put a formula for DIFF as ES-T1ES (in Excel) or make an update query for DIFF in Access. Due to MSOffices logic the difference will be calculated without any day-offs.
And the last step: import file back to P3.
Note: You may delete all columns except Activity ID and DIFF.
A little bit complicated but it works.
If you have any questions, dont hesitate to contact me.
Andrew
22 years 4 months
Member for22 years4 months
Submitted by Shahzad Munawar on Mon, 2004-11-22 07:01
Leave it and forget it. I think there is no simple solution. Its high time for Primavera to develop the option of getting specially the Variances in working days or calendar days. For simple reason when we talk about delays it always means calendar days not working days and LD are applied on calendar days delays not working days delays.
21 years 5 months
Member for21 years6 months
Submitted by Maria Ahlberg on Mon, 2004-11-22 04:01
You can assign a calender with only workingdays to the activity you have trouble with, but to make the figures correct you have to show the same calender for that activity in the main project as in the target project.
If you often want to show the total amount of days, why not allways use a calender with 7 workdays?
22 years 7 months
Member for22 years7 months
Submitted by Dayanidhi Dhandapany on Sun, 2004-11-21 12:54
If it for your one last activty to get the result as you want can just define Thursday/Friday as working day(Exception).I think this will help in your case.
Let me make it more clear. If you deduct 18-Dec-2004 from 1-Jan-2005 the answer is 14 days but in Variance Target 1 early finish column shows -12 days since 2 Fridays are non working days.
How to get -14 days as answer in P3 ?
Anyway thanks for response Shazad.
22 years 4 months
Submitted by Shahzad Munawar on Sat, 2004-11-20 14:20
24 years 6 monthsRE: Variance in Calendar Days
Paul E Harris
www.eh.com.au
21 years 4 monthsRE: Variance in Calendar Days
Hi Paul
Thanks a lot for your suggestions but my problem remains as it is.
I did it again using temp. variables as suggested by you but still the answer was not like Excel.
Custom Data Item
DIF N 3
Global Run
If PCT NE 100
Then
&DFA = EF
&DFB = T1EF
&DIB = &DFA - &DFB
DIF = &DIB + 1
Answer
&DFA = 1-01-05
&DFB = 18-12-04
&DIB = 12 ( In Excel (1-01-05) - (18-12-04) = 14 )
DIF = 13
&D1 = EF
&D2 = T1EF
DIF = D1 - D2
DIF = D1F + 1
Paul E Harris
www.eh.com.au
Hi Paul
Here what I did after your suggestion but answer was still the same previous 12 days.
Custom Data Item
D1 F 7 Early Finish
D2 F 7 Target Early Finish
DIF N 3 Var In Days
Global Run
If
PCT NE 100
Then
D1 = EF
D2 = T1EF
DIF = D1 - D2
After Run
D1 = 1JAN05
D2 = 18DEC04
DIF = 12
Deduction is not like in Excel where (1-1-05)-(18-12-05) = 14.
Are you sure P3 treats dates deductions as Excel treats ?
Paul E Harris
www.eh.com.au
Thanks Andrew.
I was just interested to get the answer without using other software.
20 years 11 monthsRE: Variance in Calendar Days
Andrew
22 years 4 monthsRE: Variance in Calendar Days
Razi
Sure and no doubt that LDs are always applied on calender days not working days.
Thanks guys.
21 years 5 monthsRE: Variance in Calendar Days
22 years 7 monthsRE: Variance in Calendar Days
yes it is possible, you can change your calendar working days accordingly to suit your requirements.
21 years 3 monthsRE: Variance in Calendar Days
You may add new item as " delayed days " in Custom data items and can show "number of days delayed" in this item as per variance
