Limited Activities in P3
21 years
you people might be right. well i was using the academic version of p3 thats why i was limited to 60 activities
thanx any way in solving my problem
23 years 8 months
If your P3 is version 3.0, I strongly recommend to reinstall the software, may be more serious is install the software on other machine rather the current one.
I remember a case that acedamic version is installed and removed. However, some installed information cannot remove from the registry due to some policies setting, all later version installation are not successful,
22 years 7 months
If it works only for 60 activities or so, then definitely it will be a demo version..........
21 years
Iam using p3 version 3.0 and iam not using a academic or trial version anyways thanxs for replying me
regards
mohsin
22 years 10 months
You definitely are using the inexpensive academic version of P3 that is designed only for teaching. It is designed to work this way. If you want to be able to add in more than 60 activities, then you will need to purchase a full version from a Primavera Representative. Good luck!
23 years 8 months
Which P3 version have installed?
For version 2.0 demo version or acedamic version, there is limitation on number of activities and other functions.
