Since MSP helpfully decided not to allow you to save as MPX, you can either open your Project file in MSP98 (assuming you still have a spare copy) and then save it as MPX, or,
P3 have written their own routine which is freely available on the knowledgebase, extract given below:
Hope this helps
Paul
The following is a Primavera Knowledgebase solution:
Solution ID: 200316155826
Goal How to use the MPP to MPX Utility.
Fix Primavera provides a utility to convert Microsoft Project MPP files to MPX files. MPX files can be converted to P3 files. MPP files can not be directly converted to P3 format. To use the utility, Microsoft Project must be installed on the computer.
NOTE: P3 does not need to be installed to run this utility.
Often I need to switch between P3 and MS project. I was facing the same trouble using MS project 2002 becuase it doesn’t have this option!!. Then parallel to this I started using MS project 98 which has this conversion option. How come the latest version is not having this facitltiy I don’t know even !! Friends let’s discuss this now . . .
23 years 8 monthsRE: conversion of mpp/p3
Just a reminding note.
Any client machine install this MPP to MPX conversion utility must have Project installed.
24 years 9 monthsRE: conversion of mpp/p3
Gents
Hope this helps
Paul
24 years 6 monthsRE: conversion of mpp/p3
Try this thread:
RE: conversions to P3
21 years 2 monthsRE: conversion of mpp/p3
Deleted by moderator
21 years 1 monthRE: conversion of mpp/p3
Deleted by Moderator
Well Haslan :
Sentence deleted by moderator
Muhammad Ali
PP Id 7575
UAE
