P3 on Windows XP
23 years 8 months
Is it true, I use P3 v3.1 with SP2 on winXP pro over a year and haven’t meet this problem.
May I know the software configuration? Standalone or network installation? What’s the P3 folders path?
22 years 6 months
Hi Guys,
this problem could be encountered when u r printing through print preview, but if u print through the printer icon on the top it will work.
regards,
Ahmed
21 years 10 months
Hi Guys,
I am assuming that you have just installed your XP OS.
Even if you are using an network printer you have to install it to work for you.
If your network using a printer which is shared by a computer then do the following:
- Control panel>printer>network printer>browse for a printer and install it.
If your network using a printer which has IP address and stand alone then
- Control panel>printer>local printer>create port>choose TCP/IP> type in the IP address and install.
- Ip address usually available with system administrator.
IF you have already installed Acrobat® Distiller then you can print becasue it create a PDF printer for you.
Dinesh
22 years 6 months
I am also faced the same problem. When I try to see the print preview, i am getting an error message "no printer is installed". The printer is installed on the network. I could able to print on Adobe Acrobat. I dont know why it is not getting printed on on the network printer.
Ravi
