You need to install the Pervasive 32-bit ODBC driver that Primavera sends out, i.e. "Pervasive Software ODBC-32" version 2.04.02.10.
1. See Technical Bulletin 200052692630 - "Setting up SureTrak v3.0 for 32bit ODBC", and Technical Bulletin 1999330113639, "How to install the Pervasive 32-bit ODBC drivers" for instructions on installation and configuration.
2. If using SureTrak, save your project as a Project Groups type project if you haven’t done this already.
3. Go to Tools, Update Data Dictionary to create your *DDF files .
4. Create the Data Sources for the SureTrak projects you want to work with through the 32-bit ODBC driver in Control Panel.
5. Make sure that the project is not open in SureTrak or P3.
6. In Microsoft Access go to File, New Database to create a new database.
7. Give the database a name.
I hope this helps
24 years 5 months
Member for24 years5 months
Submitted by Roger Gibson on Wed, 2002-07-10 03:26
23 years 7 monthsRe: How to link Access to P3?
Thank You for your valuable info.
Thank You.is a very useful info. and i am trying now.
24 years 8 monthsRe: How to link Access to P3?
On the P3 knowledgebase
Bulletin Number: 200011616333
I hope this helps
24 years 5 monthsRe: How to link Access to P3?
There is an add-on made by Primaplan called Flint that allows you to do
this, have a look at Primaplan.com
24 years 9 monthsRe: How to link Access to P3?
Try This Site
Link
