If you are using fragnets, Id encourage you to look at eTaskMaker. Its a more sophisticated and scalable system for managing repetitive project scope.
My fragnet function in P3 is not working...if I say say store fragnet, it is showing the message ..."unable to add fragnet to project" for all schedules.
Hi Ali,
As I know, Fragnet can be a small project, a sub project or a series of activities from a existing project, which can be saved separetly in a template and you can use it sevral times, in the current project or any other project. So there are diffrences between Fragnet and Copy-Paste (as Mohd mentioned).When we copy a series of activities,they will save in the clipboard as a temporary data and will be replaced by other data later. So you can't use them as a template data.
Please note that all internal relationships will remain when you retrive a Fragnet, but you will need to define all external relationships after retriving.
If you need more info regarding the store & retrive a Fragnet and more usage of this command, please don't hesitate to contact me.
best regards,
A.Vessali
23 years 7 months
Member for23 years7 months
Submitted by Saleh Elshobokshi on Tue, 2002-03-19 10:09
Yes Ali,
fragnets are a group of activities that are repeated several times in a project, example are the construction of RC slabs, walls, columns, and stairs in a multi floor builfing, also the procurement of goods. etc.
as far as i concern, and in simple term, like a "saved" copy and paste. think of it like copy and paste. in some how, (as far as i concern), i prefer copy and paste, as u have a better control in renaming, and sometimes with relations to existing activities.
regards,
mohd
The 256k document (fragnets2.pdf) referred to in my previous message is now available at http://www.anzpug.org. Select from the menu bar on the leftside of the home page, "Useful Information" under Resources, then the second item on that page.
Colin Cropley
23 years 9 months
Member for23 years9 months
Submitted by Colin Cropley on Sat, 2002-03-16 13:15
Ali
Yes, fragnets are a good choice for repeating sequences of activities, but it is not a good idea to call them "Project Loops" as this indicates a set of activities that loop back on themselves (sequence of successors ends in a predecessor to first activity in the loop).
The instructions in P3 help are pretty clear on how to build and use fragnets, but if you cannot follow them, please email me and I will email you back a document with screen dumps explaining how to build and use fragnets. The document was prepared for a particular project, but can be followed for any situation.
Colin Cropley
20 years 7 monthsRe: Fragnet & Project Loop
Thanks Mr.Bernard,
Am checking the software...thanks for the information.
with regards,
Syed.
22 years 11 monthsRe: Fragnet & Project Loop
Bernard Ertl
InterPlan Systems
Dear All,
Can anybody help me solve this.
thanks and regards,
syed
24 years 1 monthRe: Fragnet & Project Loop
Hi Ali,
best regards,
A.Vessali
23 years 7 monthsRe: Fragnet & Project Loop
Yes Ali,
24 years 3 monthsRe: Fragnet & Project Loop
regards,
mohd
thanks for it. let me read it. i will let u know if any question, if u never mind it.
my regards, mohd
23 years 9 monthsRe: Fragnet & Project Loop
Colin Cropley
Ali
Colin Cropley
