Copy Protect on Power Point Files
21 years 8 months
Mike,
I think that what Alexandre suggests should work. Make sure you cannot edit the watermark; maybe you can save the slides as picture files and then into pdf or back into Power Point.
PDF files not from a scan can be edited to some extent with Adobe Acrobat Pro.
Always keep editable files and their backups.
Keep open the option for very long and difficult to crack passwords. Microsoft site have some suggestions. These passwords can only be cracked by “Brute Force” methods and will take so long will deter almost anyone.
A combination af all tricks plus a long password will drive crazy any hacker.
22 years 9 months
Mike,
something you can do and it works: insert a watermark in every slide, that would say something like "Mike Testro has written this fantastic slide show, thanks for him"
I am sure that all these horrible thieves will cross the street instead of using your slides under their name.
Alexandre
19 years 10 months
Hi All
Thank you all for your valued input - you have confirmed what I thought - it can’t be done.
So I will fall back on printing and binding and distributing hard copies - if anyone wants to scan pages and convert to powerpoint then let them.
22 years 9 months
Hi guys,
unless you put a H bomb or the virus of the A-H1N1 influenza in the PowerPoint file, you cannot make 100% sure that nobody at all will ever stole the file
as you know, most of the thieves will try to crack the file only a few minutes; and they do not know all the tricks your are mentioning here
Alexandre
21 years 8 months
Mike,
A few months ago an owner sent us an MS Excel spreadsheet password protected; I unlocked it using Elcomsoft MSO Password Recovery and recovered the hidden password. This was the spreadsheet where we were to submit our bids.
Even MS Windows have been hacked, but general use software seems to be easier to unlock.
http://www.elcomsoft.com/
For PDF files I still prefer PDF Password remover.
16 years 3 months
I would suggest
Make a hard copy.
Then delete the file, throw in the re-cycle bin. In this way nobody can copy the power point file.
Simple
Thank you,
Scarlett
18 years
Mike
If your intention is to have unique users or if you wish to protect users from making changes, the best way might be to set a password for the PPT file. In any other case, if the powerpoint is opened, the content could be copied.
For setting up the password: Tools>Options>Security>Password to Open/Modify
Kind regards
Rubas
21 years 8 months
Very PDF Password remover can remove the protection at the click of the mouse, very fast no need of "brute force".
100% success up to date. You can e-mail me your PDF I will return it unlocked.
22 years 9 months
Mike,
I don’t know how to do, and if only it is possible to protect a PowerPoint file; I would personnaly "print" the PowerPoint to a pdf file and protect the file against copy and print; the only way for a user to copy your file would be to capture the screens
Alexandre
