Float Path in Group and sort
12 years 6 months
Note if you want to use the Float Path, at least on ver 16.1 or older you have to go to Tools, Schedule, Options, Advanced, - the check the box that says Calculate Float Paths, then you have to put a number - I do not understand why it asked, so I just put some random number like 300.  When asked to analyze a schedule - Float Paths is the first thing I do.  Schedules are generally by WBS - you can't follow them, the Float path shows you the sequences straight through- most important down (common sense will over-ride some).
12 years 6 months
19 years
Right Click on the toolbar and select the Activity Critical Path Toolbar: see below
Activity-Critical-Path
16 years 3 months
Rodel where is this tool bar located
19 years
If your schedule had a multiple path, the best way of checking the driving activity is to use the float path. The P6 r21 had a new tool bar that calculate float path or driving predecessor and successor activity called Activity Critical Path tool bar.
