Thanks Rodel - this is possibly one of the most useful posts I've seen - this same issue was driving me nuts (I'm on V17 but must get round to updating).
I needed to uninstall Java (which was V8) go back to Oracle's site and install V7, them point at it as you posted.
18 years 3 months
Member for18 years4 months
Submitted by Nick Jackson on Wed, 2024-04-10 12:58
16 years 3 months
Member for16 years3 months
Submitted by Zoltan Palffy on Tue, 2022-05-10 13:16
Primavera P6 rel 15.xx + up or higher version is using Java 7. If you upgraded your Java to higher version, it may not load third party API such as MSP import/ Export, Schedule Analyser, Visualiser or any P6 third party API using Java environment. To make sure that you have a correct Java (jre), you can checked your machine by:
If P6 installation is using 32bit, the java folder (jre7) should be located under C:\Program Files (x86)\Java\jre7
If P6 installation is using 64bit, the java folder (jre7) should be located under C:\Program Files\Java\jre7
If you find Java\jre7 folder, make sure that the JAVA_HOME environment is set.
Setting JAVA_HOME
The JAVA_HOME environment variable points to the directory where the Java runtime environment (JRE) is installed on your computer.
The following tasks provide the information you need to set JAVA_HOME on Windows or UNIX systems.
To set JAVA_HOME on a Windows system:
Right click My Computer and select Properties.
On the Advanced tab, select Environment Variables, and then edit JAVA_HOME to point to the location of the of the Java Runtime Environment (JRE).
18 years 3 monthsThanks Rodel - this is
16 years 3 monthsroll back the java version
roll back the java version and turn off automatic updates for java
and as Rodel said check the environment path and make sure that it point to the correct location for java home
19 yearsPrimavera P6 rel 15.xx + up
Setting JAVA_HOME
